Battery Voltage Sense Diff Amp
pbishop
Joined Oct 23, 2023
Hi, Circuit is intended to measure a high voltage battery voltage and input it to an ADC to monitor the voltage.
Hoping someone can confirm that I am viewing this circuit appropriately, assuming ideal op amp rules apply. Trying to come up with an equation to relate the Input Voltage to the output voltage.
Actual Circuit
Circuit w/ Op Amp Converted to Ideal Components.
I'm thiking I need to solve a system of equations, just not sure how messy that is going to get?
Ian0
Joined Aug 7, 2020
13,288
Delete Rb and Rd, then it's just Rc/Ra.
Is the battery voltage fully floating? If so, the common-mode voltage range of the op-amp may be a problem.
pbishop
Joined Oct 23, 2023
Yes, the battery is floating. I'm inheritting this circuit so I don't have the luxury of making changes for now.
pbishop
Joined Oct 23, 2023
My intention of having the "Vout" voltage source is to represent what the output voltage needs to be across the feedback resistor to drive the"Input Terminal Nodes" to the same voltage.
