Good morning all,
At first, I'm not so good in the English language so excuus me for that.
My Question:
I want to test 2 serie battery's (12V+12V=) 24V 7Ah (C20 test) lead acid VLRA type.
They are used to power a motor (24VDC, maxload = 40ADC) (maxload only occurs only for a few seconds (20-30sec)).
After doing this they will be recharged.
How could I test these battery's ?
I want to know how the behave.
What do I want to accomplish is:
A emplacement of a battery connectect to a Resistive Loadbank (to simulate the motor) and I want to read de battery by checking the voltage with an ADC (microcontroller) and send this to a PC for analysing.
What I thought so far:
A lead acid battery cannot read out correctly when there is an load attached to this battery, so I want to try to switch off the load and then read it out.
The resistive loadbank is not a complete simulation of a motor but would it be enough?
P = U*I = 24VDC * 40ADC = 960Watt, so i need to dissipate a lot of heat.
If I want to withdraw 40A out of the battery I need to use a 0.6ohm 1kW resistor (or a lot of resistors in parallel), but when the load is attached to the battery, the OCV (Open Circuit Voltage) drops, so I won't withdraw 40A from the battery anymore. how to solve?
I've checked these topic's:
Electronic Loads A constant current withdraw.
Power MOSFET is core of regulated-dc electronic load
1) How to withdraw 40A from a lead acid battery (for only a few seconds 20 -30 sec)
2) How to read the lead acid battery out correctly.
3) The resistive loadbank is not a complete simulation of a motor but would it be enough?
4) How to withdraw a constant current from a lead acid battery?
Any thoughts, comments and help would be greatly appreciated.
Greets,
Leek1001.
My Question:
Greets,
Leek1001.
