Battery Recharging Circuit Assistance
Stovie
Joined Feb 17, 2020
5
Hello, I am currently working on a subsystem of a project and have ran into a roadblock of sorts. I need to make a rechargeable battery circuit (12V using a battery pack of 8 AAs is what is being used currently) that will activate in the event of the 12V main power going down. Ideally, when not in use, the battery circuit will be able to charge via the main power source. The current design I have allows for the batteries to charge, but there is nothing in place preventing it from overcharging, causing damage. Is there some sort of solution for this? The ideal solution I am looking for, if it exists, would be that the batteries would be charged to 12V, then stop charging. To put it simply.
28,595
Some types of batteries have a specified "float" voltage which can be applied constantly and not cause an overcharge, while stll holding them at full charge. For that you need a stable regulated supply that is set to the correct voltage.
Stovie
Joined Feb 17, 2020
5
I am currently using Ni-Mh batteries. I was hoping someone had a circuit schematic that may work as a solution.
Picbuster
Joined Dec 2, 2013
1,062
Look at the lt1513-2
Picbuster
Stovie
Joined Feb 17, 2020
5
8 Ni-Mh batteries has a nominal output of about 9.6V.
You need 10 cells to give 12V.
True. After checking the load (electric lock actuator), the nominal voltage of 9.6V is enough to activate the lock. It functions fine, I just need to have something in place to keep the batteries at nominal voltage.
38,946
NiMh batteries can be continuously trickle charged with a current no greater than 0.05 of the battery Ah rating.
That should be sufficient to keep the battery charged if the battery is only used infrequently.
Stovie
Joined Feb 17, 2020
5
thanks for the info! The only issue now would be the overcharging prevention
28,595
The charge current can be kept indefinitely at 0.05 of the Ah rating or less without overcharging.
That can be done with a proper sized resistor to the charging source.
I suggest also having a voltage regulator before that "properly sized resistor to assure that variations do not lead to an overcharge situation.
