At first glance, one might think some current flow from a +12V wire to chassis is a fault, but that current will still return to the battery ground terminal through the body grounds, therefore it can't be detected unless all body grounds are isolated into a single circuit and all proper loads have a return wire to the battery. If all proper loads have a ground wire and the entire body is isolated from them, you can measure current from the body grounds.you are asking about something that might not yet exist except in your mind,
In a vehicle that uses what is essentially a one wire with common frame ground return design it would be almost impossible to do leakage testing without having every single live line disconnected from its end point be it a switch, relay, control module, security feature, or remote controlled function.Battery ground fault that means how to do earth leakage of battery?
I agree. That 1948 Ford pick-up truck I re-wired was a very rare exception.By far the most common cause of vehicle batteries going dead is not from bad wiring leaking current
