Here is a hand drawn schematic of the circuit I am using with the A23 12 Volt Battery.
Hi,When the switch is in the Off Position, the Battery is not connected to anything.
NO!!! The amazon page claims it to be A "SIZE A-23" battery. Battery size is a code that is intended to convey the physical dimensions of a battery. Really, it has no other purpose, although some folks believe otherwise.SCHEMATIC PLEASE
Edit: Note that 0.48mA is 480 microamps (480µA) or (0.00048A)
The Amazon page claims it's a 23 amp battery. It's not! It's the wrong battery for your application. Unless you can show us a schematic and pictures of the project. 12 volts doesn't mean anything without understanding how much current is being drawn and for how long. Yeah, your battery is going to go bad quickly.
. See post #11NO!!! The amazon page claims it to be A "SIZE A-23" battery. Battery size is a code that is intended to convey the physical dimensions of a battery. Really, it has no other purpose, although some folks believe otherwise.
In my mind what is in question is how the TS is coming to the conclusion the battery is draining when disconnected. Only two modes of failure can account for that outcome. The switch is not fully isolating the battery or the battery is somehow defective. While this is what the TS is telling us - what we don't know is by what means is this conclusion being formed. A new battery measures 12V. After one use and after some period of time the device is activated again only to find the battery is too weak to initiate the circuit again and thus the TS comes to the conclusion the battery has somehow mysteriously drained. The one single factor which we can not determine is how the TS is coming to this conclusion.The TS clearly states the above quote, the battery drains when the power switch is set to OFF, so what is the point of commenting on the battery power???
the TS should remove the battery and monitor its voltage over a few weeks. I'm confident if the TS does that he will discover the battery is not draining at all.Disconnect the battery and measure the voltage for a few weeks and track the results. It's possible the battery may be self-draining. If you're using Li-Ion batteries you could have a defective cell.
CLEARLY the listing copy was done by A TECHNICALLY ILLITERATE copywriter person! An individual unable to understand the more detailed information given . And likewise, if there was a proof-reader, they also had no clues.. See post #11
Pretty clear to me they were advertising this battery as being 23 amps. Of course I know better, but they cater to people who don't always know what they are buying. "A 23 AMP BATTERY ? ? ? HOLY MOLEY, THAT THING WILL DO WHAT I WANT FOR A YEAR AND A DAY!" is what they might think or say. Amazon does present this as a 23 amp battery. Of course those who are writing these items up don't always know what they're talking about. It's easy to misrepresent a product without trying. I've seen this a good number of times. The buyer has to be acutely aware of what they are buying. And I've fallen victim to this issue myself on more than one occasion.
