Hi all,
Can anyone advise here please.
I can understand that all recharge batteries degrade over time and loose there ability to charge and hold that charge.
Question is, what would cause these batteries to fluctuate?
Even with Li-Ion, For example, the battery could charge to 1500 mAh, next charge it could be down to 900mAh, then on the next charge it could be 1400mAh.
thanks in advance.
Even though the same charger is used, and the temperature around the battery and charger is always the same.
thanks in advance.
