Battery charger protection circuit
jtn
Joined Mar 27, 2017
22
Hello everyone. I just joined this forum. I try to design a charger protection circuit based on the logic that when battery is fully charge, the voltage is in floating mode and the charge current is from full charge current to almost 0A. In normal mode the relay connect the charger to the 12V lead acid battery. Once the battery is fully charge, voltage is in floating condition > 14V (?) and charge current collapsed to 0A, Transistor Q2 will turn on relay coil and disconnect the charger. Could you please review if the circuit is making sense. Thanks
ronv
Joined Nov 12, 2008
3,770
No schematic. You may need a moderator to let you post one before you have more posts. I'll try to let them know.
Dodgydave
Joined Jun 22, 2012
11,395
Its far too over complicated,!!
no need for Q2, use the fet Q1 to switch on the relay, also your opamp configured for voltage sensing will be in reverse and wont allow it to start charging, and it's not got hysteresis.....
LesJones
Joined Jan 8, 2017
4,544
Also it does not latch off after the battery voltage exceeds 14 volts. The battery voltage will drop below 14 volts a short time after the charger is disconnected and it will switch back to charging the battery.
Les.
jtn
Joined Mar 27, 2017
22
I thougth the op-amp is configured in the way that will latch off Q2 in normal operation. I will eliminate Q2 an simplify the circuit
Thank you for your comment
jtn
Joined Mar 27, 2017
22
Les.
The logic here is I need both conditions (Voltage and Current) in order to latch on Q2. Even voltage is fall back below 14V but current is at 0A, X1-out is at 0V and still holing Q1 Off. Should I remove 2 andd D5 ? Thank you
