I am doing a project with a DC Brushless motor with a Stall Current of 20A at Nominal Voltage (12v). It a "no load" current draw of .52A @12v.
Link to motor: https://www.servocity.com/612-rpm-hd-premium-planetary-gear-motor
Due to the size of my poject I was hoping to use three Samsung 25R 18650 batteries wired in series. They have a discharge current of 20A Maximum Continuous.
Link to Battery: https://www.imrbatteries.com/samsung-25r-18650-rechargeable-battery/
At max charge the batteries could be 4.2V each, putting the voltage just above the nominal motor voltage and raising the stall current above the rated discharge current of the battery. In addition to this I am running some LEDs, a microcontroller and some other small components off of the same battery. Is this safe? Would I be pushing the batteries too hard? What if I used a BEC for the motors?
The battery page has a lot of warnings about it being unprotected and using only proper circuitry etc. Is this out of the realm of a hobbyist given how close to the limit I am pushing the battery?
In a perfect would I'd be able to wire these in, and add some kind of charging point so they can stay contained within the project and be recharged as necessary. Is this too wishful thinking?
My alternative is to use two of these wired in series: https://www.amazon.com/TATTU-Airsof...544119539&sr=8-3&keywords=tattu+stick+battery
