basics for NUCLEO-F411RE STM32F411RET6 STM32 Nucleo Development Board
shteii01
Joined Feb 19, 2010
4,644
What do you learn about electronics from playing with an arduino? Writing code does not teach you how circuits work or how a transistor amplifies or how an op-amp works. If you want to learn programming that is one thing, but if you want to understand how electricity and electronics work that is an entirely different thing. Please do not confuse learning to write programs with learning how circuits function.
Never underestimate value of instant gratification.
28,615
You are mistaking patience, persistence, self control for: this product is so poorly developed that I need tutorial for the product tutorial.
Starting at the beginning is often a good choice. Establishing a foundation of understanding will provide a basis for the additional explanations that will lead to insight and understanding.
For understanding how an LED works, there is the basics that current needs to flow, qualified with the fact that for a diode to allow enough current to flow the voltage must exceed the required forward drop value. The actual physics of that gets a bit complex, and since most folks do not build their own LEDs, that knowledge is not really needed. Probably none of that is covered in the instructions about how to write code to switch on an output line.
A Microcontrollers 0
