So, I bought a barcode scanner:
https://smile.amazon.com/Automatic-Barcode-Scanning-Bar-code-Adjustable/dp/B00406YZGK/
I'm wanting to do something abnormal, of course, because using an electronic device as-is just isn't good enough. It works great when plugged directly into a computer via USB. When I try to solder leads directly onto the VCC, GND, D+, and D- pins and then connect those to a Raspberry Pi, it doesn't show up. I then tested continuity in the cable it comes with it - basically one of these:
https://sc01.alicdn.com/kf/HTB109vi...LS2208-Symbol-BarCode-Scanner.jpg_350x350.jpg
I get continuity between VCC and GND but not D+ and D-. Does anyone know what's going on, here?
