I am using latest Adafruit_Thermal library, arduino mega 2560 & using it to print barcode. Issue is barcode is printed but my mobile app is unable read it. tried multiple apps also, but not reading.
Attached is code & output print.
I have tried almost all opotions in adafruit lib like CODE39, CODE93 & others, all gets pritned but not able to scan.
need to print digits only 0 to 9 only. In image attached, top part is removed it had customer info.Text is printed correctly no issues.
Code:
void print_barcode(uint16_t g_serial_number)
uint8_t temp1;
uint16_t temp;
char_t barcode_str[14];
char_t serial_number_bytes[5] = {' ', ' ', ' ', ' ', ' '};
temp = g_serial_number;
temp1 = temp % 10U;
serial_number_bytes[4] = temp1 | 0x30U;
temp = temp / 10U;
temp1 = temp % 10U;
serial_number_bytes[3] = temp1 | 0x30U;
temp = temp / 10U;
temp1 = temp % 10U;
serial_number_bytes[2] = temp1 | 0x30U;
temp = temp / 10U;
temp1 = temp % 10U;
serial_number_bytes[1] = temp1 | 0x30U;
temp = temp / 10U;
temp1 = temp % 10U;
serial_number_bytes[0] = temp1 | 0x30U;
for(cnt = 0; cnt < 8U ; cnt++) // fill with zeros
barcode_str[cnt] = '0';
for(cnt = 0; cnt < 5U ; cnt++)
barcode_str[cnt+8] = serial_number_bytes[cnt];
barcode_str[13] = '\0';
printer.setBarcodeHeight(19);
printer.printBarcode(&barcode_str[0], CODE39);
Serial1.write(14); //move to next label
