Back up battery - 24 VDC circuit
tibibs
Joined Aug 25, 2021
8
I have a device that is connected to a 24 VDC power supply.
I would like to get a battery that takes over the supply in the event of a power loss. I don't need to charge the battery when the main power supply is on.
the output current needed is very small, max 500 mA.
do you know if there are any standard PCB or IC that can do just this?
thank you,
Tibibs
tibibs
Joined Aug 25, 2021
8
the device support easily a low voltage (23.5V). Actually it could even go down to 12VDC or so. My battery is actually a 18V battery for powertools (it will be easy to supply, replace, check the voltage status etc...)
