B max flux density
MATT838383
Joined Jul 31, 2019
144
i have a last question, is this formula correct for windings calculation? have you got an other way to calculate windings ferrite transformers?
(12X100000000)/(4X100000hzX330BmTX0,97mm²)= 9,37! is that rigth for a ETD34?
thank you!
Jony130
Joined Feb 17, 2009
5,600
Wow, this is a lot of power 330V*5A = 1.65kW
And the input current (drawn from 12 voltage source) will be larger then 1.65kW/12V = 138A.
So, unfortunately, I cannot help with this. Building such a high power converter is not an easy task.
MATT838383
Joined Jul 31, 2019
144
why not? a 100watts or 1000Watts have the same functions! only the diameter and the core change!
but i only need a formula precisly for the numbers of windins of my etd34!
bertus
Joined Apr 5, 2008
23,005
The EDT34 core is not capable of providing 1650 Watts , @Jony130 mentioned.
This is what I found online about the EDT34 core:
ETD34 Switching Power Transformer Electronic Transformer
Ⅰ . ETD34 high frequency transformer size(unit:mm)
Ⅱ . ETD34 high frequency transformer performance
1.working frequency:40kHz-500KHz
2.output power:15 to 60 W
3.operating temperature:-40℃ to +125℃
4.storage temperature:-25℃ to +85℃
5.Store humidity:30 to 95%
http://www.ht-transformer.com/high-...switching-power-transformer-electronic-t.html
Bertus
MATT838383
Joined Jul 31, 2019
144
Ok bertus lets try with etd34 how can i calculate the primary secondary windings? have you got a formula for it?
thank you
bertus
Joined Apr 5, 2008
23,005
With the EDT34 core, an inverter of 60 Watt is the max.
At 60 Watt and 330 Volts you will reach a current of 180 mA max.
What grade of core do you have?
Bertus
DickCappels
Joined Aug 21, 2008
10,661
The design process is a little "large and bulky" to be described in a forum. I know you just want to know the formula and get on with the design but you need the right formula for your design. For that, you might find the design guides at the URL below to be of help. If nothing else it will help you prepare an explanation of exactly what you need to know to get the job done.
https://www.mag-inc.com/Design/Design-Guides
Edit: Corrected URL.
