I think it worked after I rebuilt the the hex file.
when I hit programmed I get
Getting isp parameter .. SD=0x06 Ok OK
Reading flash input file .. OK
Setting mode and device parameters .. OK
Entering programming mode OK
Eraseing device ... OK!
programming flash .. OK
reading flash OK
Flash contents is equal to file OK
Leaving programming mode OK
So I think it programmed the chip I am going to stick a led in and see if it blinks.
Anyway could you explain what the avr simulator changed that made it work?
Or was it just the fact I was at to many Hertz while programming.
reading flash OK
