Automatic polarity reversing relay
sghioto
Joined Dec 31, 2017
8,750
No that would be simple they are just switched on for x duration then off. Ideally I can find something that would be inline of the power susply and motor that every time the ac timer powered the dc power susply ot would automatically reverse polarity.
Can these AC timers be programmed for at least 2 events per day?
Is this system operating now manually and if so how is it configured?
ElectricSpidey
Joined Dec 2, 2017
3,358
This system can be accomplished with the following parts.
1 24 hour Intermatic timer with adjustable "on" times.
1 Togglable 4PDT relay.
Operation as follows...
2 poles reverse the polarity.
1 each pole enables and disables the limit switches.
Each timer event changes the state of the relay...reverses the polarity and activates the proper limit switch.
The system does not rely on the timers to stop the activator.
The system is basically fail-safe as when the polarity tells the actuator "UP" the "UP" limit is active" when the polarity tells the actuator "DOWN" the "DOWN" limit is active.
The only issue is toggling the relay, this could be something off the shelf or perhaps a circuit could be built.
sghioto
Joined Dec 31, 2017
8,750
The limit switches are internal in the motor so only need a DPDT relay to reverse the polarity. The Timer is used to switch the relay but the power supply would need to be on 24/7 in this configuration unless a second timer is used to activate the power supply when required.
28,179
Certainly this exact design has been described in this forum more than once. The circuit has opened and closed chicken coops at least twice. and why would a DPDT real be used for reversing the motor when "stopped" is also a required condition??
Of course the fact that the thread poster has presented their solution to achieve the desired motion has confused several folks. And certainly LQC did point this out.
But please search "motor reversal" or "DC motor reversal" for those threads that already have the solution described in detail.
ElectricSpidey
Joined Dec 2, 2017
3,358
I understand, but when you reverse the polarity wont the limit switch that is active still prevent the movement?
I guess there is something I don't quite understand about internal limit switches.
38,764
Likely there's a diode across the switch contacts that allows current flow in the opposite direction across the open contacts when the voltage is reversed.
The diode only has to conduct current until the motor moves, closing the switch contacts.
sghioto
Joined Dec 31, 2017
8,750
Here's the proposal suggested with the components from post #12.
It starts with the motor UP and OFF via the limit switches.
At 5:00AM the timer starts Event 1 which activates the relay reversing the motor connections and the motor runs DOWN.
After appx 10 minutes the motor stops via the limit switches but the relay stays energized until 6:30AM.
At 6:30AM Event 1 ends and the timer deactivates the relay reversing the motor connections allowing the motor to return UP
until it hits the limit switches.
Event 2 repeats the operation at 6:30PM til 8:30PM.
ElectricSpidey
Joined Dec 2, 2017
3,358
Yea, that came to me about 3 seconds after I hit the post button, then it actually occurred to me that I had used that exact method years ago when I built a small ram.
djsfantasi
Joined Apr 11, 2010
9,237
How does that allow the motor to switch off??
How does what allow the motor to switch off? The motor runs until it hits the limit switch, turning the motor off. The diode bypassing the limit switch doesn’t conduct until the polarity to the motor reverses. The same occurs for operation in the opposite direction.
Reloadron
Joined Jan 15, 2015
7,926
You have a motor driving maybe a linear actuator or similar. The motor has limit switches. I don't get why or what you expect the timer to do? You travel to a limit and reverse. You can, as mentioned use a H Bridge or DPST relay.
Ron
28,179
with the use of two SPDT relays separate commands from he timer can easily be impllemented and a relat only needs to be operated during the move.
sghioto
Joined Dec 31, 2017
8,750
Ron
The timer is to activate or deactivate the relay at the times required.
I thought post #33 explained that detail pretty well.
