https://drive.google.com/file/d/0B-uy-gPp1BqRQlNjNWFWVEpyNFNfbmVjb2JCbVdRSGdaQTNz/view?usp=sharingI will start by saying my knowledge of electronics is basic. I work with computers and know enough to do basic solder jobs and cap replacments etc.
I am an audio enthusiast and like my power amps and have picked up this amp that had no power. I opened it to find the on the main PSu board the transformer had come away from it's connector pins. When I say come away I mean the pins had come away from the the coil unit not from the pcb board. The piece I am talking about is labelled 080-0003-A in the attached photo. Everything else looks in tact in the amp. No blown fuses or swollen caps and very clean throughout.
My question is a simple one can somone identify the part labelled 080-0003-A in attached photo so I can buy a replacment. I suspect it is damaged but it is just a guess. There is no signs or traumatic damage from a drop or fall on the unit so I suspect the manufacturer just didn't use enough glue to hold it in place or else it deteriorated and the unit came lose and seperated due to its weight but I am open to other possible suggestions?
The unit is on four pins that are soldered to the pcb board.
https://drive.google.com/file/d/0B-uy-gPp1BqRWVFPbEhjcFpLQ0N1UVhRbk15RlJuSGRra3FF/view?usp=sharing
