Hello to members -
I will start with a very GENERAL Question concerning Transistor Amplifier Biasing.
We have all seen on Schematic pages Voltage readings printed on the schematic at various test points and components leads from the manufacturer. These voltage notations usually are a good DC Static State confidence check of various circuits.
What type of Transistor component fault may reduce significantly the collector's bias voltage ?
Yes, in repeated Amplifier circuits replacement of the Cascaded Amp transistor's, corrects the Collectors Bias Voltage.
Curious of what type of internal Transistor Failure may cause this ?
These defective Transistor's interestingly - will Ohm -Continuity Check as though they are fine !
Any suggestive input is appreciated.
cferry7
cferry7
