I was recapping an amp and put one beefy 6800uf cap in the wrong polarity. Result - blown amps fuses and blown again when the big caps were installed correctly. It's a simple vintage BW Aura amp so I can replace everything if needed. So far just replacing the diodes and caps that are reading wrong with an esr meter. I want to stick to the original parts as much as possible but I've no clue about the brands of the two caps (pics attached). One 10uf reads 'STABILITY' (is it special in any way??), another is a larger Japan 220uf with a triangle logo on it. Would someone knowledgeable help me to ID them?
Cheers,
https://drive.google.com/open?id=1I2BMwIS1jDXzCwPEXpo_21G05biP4WWj
https://drive.google.com/open?id=1fKNLo8TMz_9aP-RkYaTp36n93CYysuak
Cheers,
