ATMEL 89C51 PROGRAMMING need ur help
arikrishnan
Joined Mar 7, 2007
5
sir,
for programming we use "h" to refer hexadecimal number.for example
MOV R2,#0FFH .
similarlly what is used 2 refer decimal number.? is it necessary to initialise the use of decimal in ATMEL89C51 programming.
MOV R3,#00D
what is the meaning of the D used in above programme.
please reply as soon as possible
please reply to my mail id arikrishnan_t@yahoo.com
22,105
If the assembler supports it, the "D" stands for decimal. Decimal is the default radix in most assemblers which is why the suffix H is required. Assemblers often have a "radix" pseudo operation to change the default radix. Which assembler are you using?
arikrishnan
Joined Mar 7, 2007
5
thanks 4 ur reply. did the ATMEL89C51 microcontroller accepts this type of code ("d" for decimal). do u have any sample programme for the same type . please send me
