ARM Assembly Language
kchandra
Joined Aug 20, 2019
Is there any assembly language programming book specifically for ARM for MSP432 P401R LaunchPad Development Kit using Keil mVision?
Papabravo
Joined Feb 24, 2006
22,116
It is not worthwhile to write, and maintain, a general purpose book because each vendor that makes an assembler does it slightly different. Your best bet is to run down the documentation for the assembler that you want to use. Since Keil makes a compiler, they must also have an assembler. That is where you need to go. If you have the Keil Assembler document, then you can look at the compiler output to see how things are done. That is what you need to do.
