Hi guys. I have some code here that runs a 4 channel servo tester. The display currently updates when the two encoders are adjusted, or when the channel is changed via one of the push buttons. I also want the display to update when the potentiometers are adjusted. Is anyone able to help?
Mod: placed your code in Code Tags, easier to read.
C-like:
#include <Servo.h>
#include <Bounce2.h>
#include <Encoder.h>
#include <SPI.h>
#include "Ucglib.h"
//attach all inputs and outputs
#define PIN_BUTTON_A 17
#define PIN_BUTTON_B 16
#define PIN_BUTTON_C 15
#define PIN_BUTTON_D 14
#define PIN_ENCODER_L_A 18
#define PIN_ENCODER_L_B 19
#define PIN_ENCODER_R_A 20
#define PIN_ENCODER_R_B 21
#define PIN_POT_A A3
#define PIN_POT_B A2
#define PIN_POT_C A1
#define PIN_POT_D A0
#define PIN_LED_A 4
#define PIN_LED_B 5
#define PIN_LED_C 6
#define PIN_LED_D 7
#define PIN_SERVO_A 11
#define PIN_SERVO_B 10
#define PIN_SERVO_C 9
#define PIN_SERVO_D 8
// Total pins used without LCD is 20
//#define channelPulseMin 500
//#define channelPulseMax 2500
#define channelPulseMin 0
#define channelPulseMax 180
Bounce buttonA = Bounce(PIN_BUTTON_A, 10);
Bounce buttonB = Bounce(PIN_BUTTON_B, 10);
Bounce buttonC = Bounce(PIN_BUTTON_C, 10);
Bounce buttonD = Bounce(PIN_BUTTON_D, 10);
Encoder encoderLeft(PIN_ENCODER_L_A, PIN_ENCODER_L_B);
Encoder encoderRight(PIN_ENCODER_R_A, PIN_ENCODER_R_B);
Servo servoA;
Servo servoB;
Servo servoC;
Servo servoD;
// Arduino Mega Hardware SPI Pins: sclk=52, data=51
Ucglib_ILI9341_18x240x320_HWSPI ucg(/*cd=*/ 45, /*cs=*/ 49, /*reset=*/ 47);
//int curEncLeftPos = 0;
int lastEncLeftPos = -999;
//int curEncRightPos = 0;
int lastEncRightPos = -999;
int curChannelSelection = 0; //
int lastChannelSelection = -1;
int channelSetMin[] = {channelPulseMin, channelPulseMin, channelPulseMin, channelPulseMin};
int channelSetMax[] = {channelPulseMax, channelPulseMax, channelPulseMax, channelPulseMax};
int channelSetPos[] = {(channelPulseMin + channelPulseMax) / 2, (channelPulseMin + channelPulseMax) / 2, (channelPulseMin + channelPulseMax) / 2, (channelPulseMin + channelPulseMax) / 2};
int channelSetLastPos[] = {-1, -1, -1, -1};
boolean updateRequired = false;
unsigned long curTime = 0;
unsigned long lastTime = -1;
unsigned long updateInterval = 5000;
void setup(void){
pinMode(PIN_BUTTON_A, INPUT_PULLUP);
pinMode(PIN_BUTTON_B, INPUT_PULLUP);
pinMode(PIN_BUTTON_C, INPUT_PULLUP);
pinMode(PIN_BUTTON_D, INPUT_PULLUP);
pinMode(PIN_LED_A, OUTPUT);
pinMode(PIN_LED_B, OUTPUT);
pinMode(PIN_LED_C, OUTPUT);
pinMode(PIN_LED_D, OUTPUT);
digitalWrite(PIN_LED_A, HIGH);
//Serial.begin(9600);
ucg.begin(UCG_FONT_MODE_TRANSPARENT);
ucg.setFont(ucg_font_profont12_mf);
ucg.setRotate270();
ucg.clearScreen();
ucg.setColor(255, 255, 100);
ucg.setPrintPos(10, 16);
ucg.print("Channel A");
ucg.setPrintPos(90, 16);
ucg.print("Channel B");
ucg.setPrintPos(170, 16);
ucg.print("Channel C");
ucg.setPrintPos(250, 16);
ucg.print("Channel D");
ucg.drawBox(0, 20, 320, 2);
delay(500);
servoA.attach(PIN_SERVO_A);
servoB.attach(PIN_SERVO_B);
servoC.attach(PIN_SERVO_C);
servoD.attach(PIN_SERVO_D);
void loop(void){
getInput();
if (buttonA.fell()) curChannelSelection = 0;//If button A is pressed then channel 0 is selected
if (buttonB.fell()) curChannelSelection = 1;//If button B is pressed then channel 1 is selected
if (buttonC.fell()) curChannelSelection = 2;//If button C is pressed then channel 2 is selected
if (buttonD.fell()) curChannelSelection = 3;//If button D is pressed then channel 3 is selected
if (curChannelSelection != lastChannelSelection){
clearLEDs();
if (curChannelSelection == 0) digitalWrite(PIN_LED_A, HIGH);
if (curChannelSelection == 1) digitalWrite(PIN_LED_B, HIGH);
if (curChannelSelection == 2) digitalWrite(PIN_LED_C, HIGH);
if (curChannelSelection == 3) digitalWrite(PIN_LED_D, HIGH);
updateRequired = true; // on changes
lastTime = millis();
lastChannelSelection = curChannelSelection;
curTime = millis();
if (curTime - lastTime > updateInterval && updateRequired){ // limit screen updates to 20Hz so user input can be handled more responsively
updateDisplay();
lastTime = curTime;
//setServoPositions();
void setServoPositions(){
void clearLEDs(){
digitalWrite(PIN_LED_A, LOW);
digitalWrite(PIN_LED_B, LOW);
digitalWrite(PIN_LED_C, LOW);
digitalWrite(PIN_LED_D, LOW);
void updateDisplay(){
ucg.setColor(0, 0, 0);
ucg.drawBox(0, 26, 320, 100);
ucg.setColor(255, 255, 255); // draw text values
for (int ii = 0; ii < 4; ii++){
ucg.setPrintPos(10 + (ii * 80), 50);
ucg.print("Min: "); ucg.print(channelSetMin[ii]);
ucg.setPrintPos(10 + (ii * 80), 80);
ucg.print("Max: "); ucg.print(channelSetMax[ii]);
ucg.setPrintPos(10 + (ii * 80), 110);
ucg.print("Pos: "); ucg.print(channelSetPos[ii]);
ucg.setColor(0, 25, 200);
ucg.drawBox(10 + (ii * 80), 140, 48, 90); // default range
ucg.setColor(200, 200, 25);
ucg.drawBox(10 + (ii * 80), 140 + (channelSetMin[ii]>>1), 48, (channelSetMax[ii]>>1) - (channelSetMin[ii]>>1)); // user set range
ucg.setColor(200, 0, 25);
ucg.drawHLine(10 + (ii * 80), 140 + (channelSetPos[ii]>>1), 48); // servo position
// show pulse min, max, and set position
void getInput(){
//Read encoder left
long curEncLeftPos = encoderLeft.read();
if (abs(curEncLeftPos - lastEncLeftPos) >= 4) { // there are roughly four presses detected from each rotation to the next detent
if (curEncLeftPos - lastEncLeftPos > -1){ // positive increase
channelSetMin[curChannelSelection] += 1;
if (channelSetMin[curChannelSelection] >= channelSetPos[curChannelSelection]) channelSetMin[curChannelSelection] = channelSetPos[curChannelSelection];
} else {
channelSetMin[curChannelSelection] -= 1; // only allow setting the lower end of the max range to the current position
if (channelSetMin[curChannelSelection] < channelPulseMin) channelSetMin[curChannelSelection] = channelPulseMin;
lastEncLeftPos = curEncLeftPos;
long curEncRightPos = encoderRight.read();
if (abs(curEncRightPos - lastEncRightPos) >= 4) { // there are roughly four presses detected from each rotation to the next detent
if (curEncRightPos - lastEncRightPos > -1){ // positive increase
channelSetMax[curChannelSelection] += 1;
if (channelSetMax[curChannelSelection] > channelPulseMax) channelSetMax[curChannelSelection] = channelPulseMax;
} else {
channelSetMax[curChannelSelection] -= 1;
if (channelSetMax[curChannelSelection] <= channelSetPos[curChannelSelection]) channelSetMax[curChannelSelection] = channelSetPos[curChannelSelection];
lastEncRightPos = curEncRightPos;
//Read buttons
buttonA.update();
buttonB.update();
buttonC.update();
buttonD.update();
//Read potentiometers
int rawPotAVal = analogRead(PIN_POT_A);
int rawPotBVal = analogRead(PIN_POT_B);
int rawPotCVal = analogRead(PIN_POT_C);
int rawPotDVal = analogRead(PIN_POT_D);
channelSetPos[0] = map(rawPotAVal, 1023, 0, 0, 180); // always allow moving a non highlighted channel
channelSetPos[1] = map(rawPotBVal, 1023, 0, 0, 180);
channelSetPos[2] = map(rawPotCVal, 1023, 0, 0, 180);
channelSetPos[3] = map(rawPotDVal, 1023, 0, 0, 180);
if (PIN_POT_A >-1)
if (PIN_POT_B >-1)
if (PIN_POT_C >-1)
if (PIN_POT_D >-1)
for (int ii = 0; ii < 4; ii++) channelSetPos[ii] = constrain(channelSetPos[ii], channelSetMin[ii], channelSetMax[ii]);
servoA.write(channelSetPos[0]);
servoB.write(channelSetPos[1]);
servoC.write(channelSetPos[2]);
servoD.write(channelSetPos[3]);
