Apex DT250A Digital Converter Box has almost no audio.
frank55
Joined Dec 6, 2013
314
I have a Apex DT250A Digital Converter Box. I have almost no audio. If I turn up the volume on the box to max and the volume on the TV to max then I can hear the audio very faintly.
The picture is great and closed captioning works great.
To make sure it is not a TV/cable problem I swapped the cables from the DTV converter with that of the DVD player and still no audio. Used the same cable with the DVD player to the same inputs on the TV and I have audio. So it is not the TV or the cable. -
frank55
Joined Dec 6, 2013
314
Is there a mute function somewhere activated?
Bertus
Thanks bertus; mute is not activated,i have another same model box that works good,besides there is still sound but it's too low, one has to turn sound on tv max to be able to listen good sound but very faded awy
frank55
Joined Dec 6, 2013
314
Is MTS activated (select second audio channel) ?
See manual page 15.
Bertus
Thanks Bertus; but it's not it,MTS is audio 1 or Audio 2 depending on the station,some station only provide Audio 1 and those that provide audio 1 and Audio 2 the volume on them is the same
frank55
Joined Dec 6, 2013
314
HI folks thanks for helping; ok i tested U4 and Q19 and results are in pic; also i have another Apex same model# and swapped the Power Sup and same result,also the mute is ok,the sound is audible mut has to all the way up on the box and on the TV,thanks again and have a Happy New Year
frank55
Joined Dec 6, 2013
314
Here U4 D4558 , i had previous taken measurements with tuner as ground ,but i learned that pin 4 and 5 are ground , i went to take measurements again but now i used pin 4 as ground and pin 8+ and i have 4.8 volts DC.
