Anyone have info on this IC ?
27,906
The first post is asking for information with no hint as to which sort of information. What is the purpose? To understand the camera or to repair it?? or something else????
lawrence101
Joined Oct 23, 2017
53
Yes I was going to attempt to repair it initially but on closer inspection I noticed that the board itself has some corrosion on it. Water or battery chemicals must have made its way onto the board surface. So I'm thinking it's not repairable.
lawrence101
Joined Oct 23, 2017
53
XC6xxxx are voltage detectors. the ICs used here are switching regulators. there is plenty of products in SOT23-5 that could fit the bill so not sure what the used ICs are. seem to be SOT23-5 package.
Yes PM it appears to be a SOT23-5 package, the pin assignment looks to be a match. The input voltage to U6 is +6.23 from the battery pack, the output voltage is +3.27, this voltage also appears on the common pin of the power switch (sw2), yet the unit will not turn on ?
34,990
The first thing to do is to clean off the corrosion with isopropyl alcohol and a soft brush.
27,906
Some corroded PCBs are repairable, some are not. And the amount of effort that should be taken depends entirely on the cost of any alternative choices. Non-TV remotes for which there is no possible replacement available may get a lot more effort .
lawrence101
Joined Oct 23, 2017
53
The traces on this double-sided board are very small and the components are all surface mount types , the voltage regulators that i thought might be the problem turned out to be ok , so the board has other issues . After some thought i've decided not to pursue the repair any further. It belongs to my brother in-law, he has several of these cameras and they are $28 a pop.
Thanks tho.
lawrence101
Joined Oct 23, 2017
53
I have to agree Bill, its a cheapish $28 camera ( he has several ) and ive decided not to pursue it any further.
Thanks for replying.
27,906
Really, though, making a detail examination of the PCB will be educational no matter if you try to repair it or not. Closely examining a fine-line PCB provides an education as to where lines can fail, and what failed solder joints can look like. That knowledge, in turn, will provide insights for future PCB inspections.
Also, if you spot a failed connection and are able to repair it, definitely a bit of improved ability. And keeping something out of a landfill.
34,990
If you have multiple units of this board that helps with the trouble shootong. Measure voltages and compare against a working board.
27,906
Of course, without a circuit and understanding how something works, all you are doing is checking for failed parts. That is not a very efficient way to service anything.
Of course, with some products, even when you know exactly what part has failed, no repair is possible because no replacement parts can be acquired.
lawrence101
Joined Oct 23, 2017
53
Agree , also like to add that if this were to be a paid job the cost could easily exceed the cost of the unit, especially as you say with no schematics and trouble shooting guides.
