PadMasterson
- Joined Jan 19, 2021
- 63
OK, so be careful with your output voltages if you are running the OP-Amps on a positive and negative supply, the output can go negative and above the input threshold of the transceiver. If I remember right, that part has an input voltage of 3.3V but I don't remember what the max is, same with a negative voltage, you don't want to exceed the ratings of the part. The outputs of OP-Amps can go close to the power voltage rails and that's why I mentioned it in my other post. You can use a single voltage part but you need to look at the specs to ensure they will swing to the levels needed by the Xcver. Both of those OP-Amps you mentioned have short circuit protection on the output so you should be safe in that respect also. I suspect you are right in that the uC controller doesn't have any ability to configure it's IO pins other than Input ot Output, but you might look to be sure. That said, you might just try a single transistor driver circuit and depending on if you need to invert the input or not and see if that will work. The output of that 741 looks really strange and I don't know if you had any load on it or not, but it just looks like a large capacitance on the output? It looks to start to go up and then starts a ramp, like something is really loading it down? I'm hoping someone else can chime in on this, I'm running out of ideas... :-/
