Anti Backlash Nuts
tracecom
Joined Apr 16, 2010
3,944
Although my question is not an electronics question, it is related to an electronics project that I am planning. The project will use some 5/8 12TPI threaded rod as part of a linear positioner, and may need anti backlash nuts. I have looked on the web and found some information, but I wonder if anyone here has hands-on experience making and/or using anti backlash nuts on threaded rod. Thanks.
22,082
We used them on an engraving table we made in the mid 1980's. The table was about 19" x 19" and used Superior Electric stepper motors direct coupled to lead screws with an ACME thread. The nuts were easy to install and did a fine job.
strantor
Joined Oct 3, 2010
6,875
From what he's done there, I don't see the need for the adjustment screws. Seems to me you could get the same effect by tightening two delrin (or walmart cutting board) nuts against each other and then fastening them together. Actually by going that route, you achieve the coveted "spring" action by placing a split lock washer between the two nuts.
tracecom
Joined Apr 16, 2010
3,944
It looks like he may have originally planned to use some sort of compression springs between the two pieces of Delrin, but then decided they weren't needed. Instead of pushing the nuts apart to force contact with both sides of the rod threads, now he's pulling them together. Do you buy his explanation that the use of Delrin reduces the wear? I can see how it reduces the wear on the rod, but what about the wear on the Delrin?
strantor
Joined Oct 3, 2010
6,875
That cutting board material is not delrin actually, but likely UHMWPE. That stuff is almost impervious to wear, which is why it's used as cutting board material. But it is not particularly strong. I would expect it to be relatively easy to rip the threads out of it. I believe him that in his application it works just fine, but I imagine his application cannot be that demanding or else it would fail. If you aren't going to be putting much load on it, should be fine for you too.
tracecom
Joined Apr 16, 2010
3,944
I think I will try making some anti-backlash nuts similar to the ones in the video, but using compression spring(s) to keep tension between the nuts...maybe a valve spring?
mcgyvr
Joined Oct 15, 2009
5,394
Good luck with the SAE threaded rod... It sucks for anything "smooth/precision"...
Go ACME at the very least
Plenty of cheap ballscrews, etc... on ebay too from China.. I'd use them in a heartbeat over standard threaded rod..
30,661
I would second the Ballscrew idea if you can find an economical source, although in that size (5/8") will not be easy.
There are rolled B.S. which usually posses some backlash, precision ground with pre-loaded ball nut is the ideal, but gets costly.
The most economical at least cost that I have used is Hiwin from Taiwan.
