Another LM3915 question!
gface83
Joined Jul 16, 2016
83
It looks like you are having trouble with a DC offset on the input of the LM3915.
Could you try a capacitor in series with the input of the LM3915 to block the DC?
Bertus
Ah right ok, ill try that! any particular value or would a 10 micro farrad work?
gface83
Joined Jul 16, 2016
83
That's weird. I tried a 10 uf and it went back to only affect the top 2 LED's and when I took the cap out and put the input back on pin 5 the pot is acting like the 10k was.
I just did some more testing and its only acting weird when I put a 1kH test tone through it, music seems to be acting as expected. I only tried a 1 kHz tone through it to give me a continuous signal while i adjusted the sensitivity.
gface83
Joined Jul 16, 2016
83
Could you try the capacitor on pin 5 and a resistor of about 10K from pin 5 to ground?
Bertus
Hi Bertus
I tried that and im still getting the same problem. When i turn the pot all the way to the left, should all the LED's go out even when there is signal going in? When I turn it all the way to the right the first 2 LED's light up, but no others. Is this normal behaviour?
gface83
Joined Jul 16, 2016
83
The good news is its working with guitar, but in order to get all LED'S to light up on hard strums I have to turn the pot most of the way up which leaves me with the first 2 LED's constantly lit.
bertus
Joined Apr 5, 2008
22,944
Could you place a resistor of 2K2 between pin 2 and 4 of th LM3915 in stead of the wire you have now?
Bertus
gface83
Joined Jul 16, 2016
83
Bertus
Hi Bertus
Sorry for the late replay. Ive just tried that and all I get now is the first LED constantly lit. The pot now doesn't do anything at all and nothing happens when I put a signal through Pin 5, just the first LED lit.
