anderson Powerpole - install into the brick wall
thor21
Joined Sep 29, 2024
435
i am looking for something similar as Anderson Powerpole panel, that i can install into the bricks wall; for 6 DC devices to connect to it.
Apparently i am not able to find anything even i cant find any Anderson panel that can be somehow installed into the brick wall?
The DC devices are max 5A.
Any suggestions?
Thank you
MaxHeadRoom
Joined Jul 18, 2013
30,817
@thor21 What is the nature of the brick wall ? standard 7-5/8" house brick, plasteered or bare?
Do you intend to remove brick in order to recess?
For the above obtain suitable box that can be recessed in and cement it in or otherwise secure it.
If there is nothing off the shelf for it, you just have to get a litlle inventive. ;)
thor21
Joined Sep 29, 2024
435
@MaxHeadRoom i think this wall is 15cm thick brick.
I have standard 230V socket installed into it. so i think i have to create a space similarly like they did for a 230V wall socket.
so i have to install standardized "box" for wall socket and on front install panel with sockets for each DC device.
MaxHeadRoom
Joined Jul 18, 2013
30,817
how do u want to install sockets into the front plate?
Mark off the position of each socket use drill to remove most of outline, finish off the required shape with file etc?
For these types of operations, you need to get a little creative !!
