Hello everyone,
I am new to the field of electronics and am just getting to grips with Logic Gates. And it's the AND Gate that's giving me problems right now
I found a circuit diagramm for it on the following website:
https://electronics-fun.com/logic-gates/
According to the truth table, the output should be 0 even if one of the inputs is 1. I build this circuit diagramm using Paul Falstad's Circuit Simulator (https://www.falstad.com/) and unfortunately the output is 1 when the second switch (see Pic_1) is closed.
I then researched for a solution and came across this YouTube video:
I rebuilt this circuit diagramm again using Paul Falstad's Circuit Simulator and it works correctly (see Pic_2).
I also rebuilt this circuit on a breadboard and it works (see Pic_3)
As far as I can understand, the part marked in red (Pic_2, 2.) is a pull-down resistor. I have read some articles about the pull-down resistors and still can't understand why the LED is not lit in this case. I would be very grateful for an explanation.
Thanks in advance!
Best regards,
Dimitri
PS: Sorry for the possible language mistakes, I am not a native English speaker.
Thanks in advance!
Best regards,
Dimitri
