I'm trying to amplify the signal of a pyranometer (Solar Power Meter), here is the device:
http://www.ambientweather.com/amsp216.html
It doesn't have a datasheet, but I was able to open it and place a 150ohm resistance between the sensor and get a voltage proportional to the readings, The bad part is I'm only getting measurements between 1 to 10mV so I need to amplify the signal to be able to use the arduino ADC.
I tried using Op Amps to amplify the signal, but I'm not able to get any readings using the ADC. It's the first time I use Op Amps so I'm not sure if I'm doing something wrong, here is the diagram:
Theoretically it works, but I'm not able to read any voltage at all with my voltmeter. I'm using a LM324 with 7.5V as source. Any suggestion is welcomed. I'm not clear if Op Amps amplify DC steady signals or only changing signals like AC? According to what if have read the Op Amps try to drive the signal to zero, so I'm guessing that's is what's happening. I will be grateful if someone cares to explain this!
Regards,
Pedro
Regards,
Pedro
