Hello all. I’ve seen a number of similar threads but not exactly sure which direction to go. I’m trying to amplify a piezoelectric accelerometer which outputs 1mV/g. But I’m not concerned with high frequency or even varying frequency. This is to simply validate the accelerometer is outputting 1mV when it is tested using a 1g accel shaker with a constant frequency of 159.4Hz. I’d like the gain to be 100 at minimum but most likely 1000 would be preferred. I’ve looked at a few pre-built packages with instrumentation amplifiers such as the AD620 and AD623 but not sure if that’s they way to go.
