amplifier
electronics1
Joined Aug 21, 2009
42
I want to transmit a song through inductive button loop to amplifier
I need to build amplifier that take the audio signals to cause an electric current flow into a button loop with diameter of 50 cm in a sufficient strength that generate a magnetic field that can receive the button loop that have some distance from the transmitter.
I understand that the magnetic field depend on the current strength that pass into the button loop and I need to build an amplifier that take the audio signals and amplify the current
What kind of amplifier I need ?
I want to learn this subject and I search after sites that explain this.
I search after electronics circuit that do this current amplify
The button loop was build with transformer but the magnetic signals are weak and I need to amplify the active current
bertus
Joined Apr 5, 2008
23,023
Do you have the current schematics?
With the schematics at hand we can have a look how to modify it.
Greetings,
Audioguru
Joined Dec 20, 2007
11,248
Some concert halls used an inductive loop around the room and deaf people wore an inductive receiver that had very high gain.
