Amplifier with direct coupling. 3 stages.Problem with gain level
Виктор Борщёв
Joined Nov 2, 2016
11
I stucked on this schema,i got some voltage gain, but it isn't enough. So i recalculated a billion of times the values and i guess i do this wrong.
Attach some screens with info and schema.
So that is schema in Proteus
Schema with values
that is schema from the book(i changed diodes with resistor)
from book
in book used very old transistor MП-40(PNP) and MП-37б(NPN)
in proteus schema i used 2N2222 and 2N2907
this is signal level simulated, Yellow - out, blue - input.
signal
i ask for some help in calculations or if u can give me a direction where to move :)
Thank you for answers
38,792
Your circuit design has a low designed gain (I simulated about 7).
For example the second stage (Q3) has a design gain of less than one (emitter resistor is larger than the collector resistor).
How much gain were you expecting?
AnalogKid
Joined Aug 1, 2013
12,268
The book schematic has an emitter follower in the 2nd stage, but you have a common emitter gain stage in your schematic. This adds another signal inversion, so the feedback resistor no longer is an input bootstrap. It would be a gain reducer if there were enough gain.
ak
Виктор Борщёв
Joined Nov 2, 2016
11
ak
well, i calculated a bit and got a bit more gain, but if i change a value of resistors for example one of them with +20 or -20 ohms, it give a big distortion of signal, its normal ?
changed R8 from 600Ohm to 580
