amplifier stage for UHF TV modulator
@lpha
Joined Feb 21, 2012
34
Hello
I found a modulator from an old analog sat receiver, it work between channel 30 to 42 (550 - 650MHz), so how can I build an amplifier stage with one or two transistor (common transistor not the RF transistor so difficult to found).
thnks ;)
@lpha
Joined Feb 21, 2012
34
nobody can help me ? I just need to amplify the very low output to 100 or 200mW with minimum of other frequency perturabtions or atenuation of video quality pics
bertus
Joined Apr 5, 2008
22,942
Common audio transistors will not at those high frequencies.
Better look for a transistor called BFW16. (see attached datasheet)
@lpha
Joined Feb 21, 2012
34
it's possible to use the test circuit in the datasheet ?
My video modulator has an output power of - 60 to - 40 dbm
