Amplifier picking out parts.
Seb1929
Joined Feb 20, 2015
26
Hello! I'm a bit off a newbie and can someone help me pick out parts for this amplifier?
I don't need the 50K potentiometer.
#12
What? All the parts are labeled. The only thing left to the imagination is that the capacitors should be rated for at least 16 volts and what country you are in.
#12
Should i use aluminum or ceramic capacitors?
Yes. The big ones are aluminum and the small ones are ceramic.
Another way to say this is, Try buying a 100 uf ceramic capacitor or try buying an aluminum 0.1 uf capacitor. Not likely you can do that.
bertus
Joined Apr 5, 2008
22,937
The difference between the TDA2822 and TDA2822M is that the TDA2822 is 16 pins and the TDA2822M is 8 pins.
There is even a TDA2822D wich is in a SO8 housing.
See the both attached datasheets to compare them.
Seb1929
Joined Feb 20, 2015
26
Looking at Digikey, I see a minimum diameter of 8 mm or a minimum height of 7.7 mm.
I think you are out of luck with your size restrictions.
Yeah, Is there any other solution instead of one 470uF? Or is there another amplifier instead of 2822M where i don't need as big capasitors?
#12
The capacitors are dictated by the speaker impedance and the low frequency range.
You can forfeit some low frequencies by choosing less capacitance.
You can choose higher impedance speakers, but the penalty is that less power will be delivered because of the low voltage available.
