Amplifier crossover distortion?
rabbitsnail
Joined Apr 9, 2018
Hi. I found this headphone amp schematic on web. I simulated the circuit and there is a problem with output waveform. without dc feedback the amplifier output sits at couple of volts higher than ground. The output signal has fairly low distortion. But when I connect an integrator between output and input, the dc sums to zero as it should, but the output now has noticeable crossover distortion, at least it looks like that. Adjusting bias spreader does not seem to have any affect at all.
link to the schematic: http://www.audiodesignguide.com/Headphone_amp/headphoneamp.html
Can`t seem to figure out what is the cause of this problem...
rabbitsnail
Joined Apr 9, 2018
Yes it is... I tried a simpler circuit to see if that`s the problem. However I just double checked with the original integrator. The issue presists and the dc offset is worse than with the other integrator. UPDATE: made a mistake wiring the bias spreader. It works now!
