I have simulate a hartley oscillator and its ouput is 4nV peak to peak. I need 6V peak to peak, any idea how to amplify it?
Now I wonder where is the location of the output.Are you sure that your oscillator output is only 4 nanovolts? How did you even find it? Some of the output has to feed back in order for oscillations to continue - that level is certainly not enough.
Here is the schematic please suggest.Maybe you can post the schematic?
I think there is no missreading, the readings are directly from the simulation probe.I think you are misreading the results of the simulation. You are asking a lot with those 1 ohm resistors. Generally, you make the oscillator and then amplify the signal. Perhaps Multisim will let you use unusual component and values.
