It's a start, and we get the general idea. The sensor is on the door, right?Ok..
here is the first flow chart I came up with...
man this is tougher than I thought..
Is this the correct way?
need some sleep.![]()
Interesting...Another option would be to have a second PIC connected to the first by the serial pin. The second PIC could then do the display and free up a lot of pins on the main PIC.
list p=16f876 ; list directive to define processor
#include <p16f876.inc> ; processor specific variable definitions
__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _XT_OSC & _WRT_ENABLE_ON & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
w_temp EQU 0x7E ; variable used for context saving
status_temp EQU 0x7F ; variable used for context saving
cblock 0x20
PORTAtemp
PORTBtemp
digit1pins
digit0pins ;right digit
LOOPCOUNT
multiplexcount
microsecondsH
microsecondsM
microsecondsL
second_flag
seconds
minute_tens
minute_units
endc
ORG 0x000 ; processor reset vector
clrf PCLATH
goto init ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
bcf STATUS, RP0 ;bank 0
movf multiplexcount, W
addwf PCL, F
goto digit1
goto digit0
digit1
bcf PORTAtemp, 7 ;toggle transistor pins
bsf PORTAtemp, 6
movf digit1pins, W ;display digit
movwf PORTB
incf multiplexcount, F
goto digitdone
digit0
bcf PORTAtemp, 6 ;toggle transistor pins
bsf PORTAtemp, 7
movf digit0pins, W ;display digit
movwf PORTB
clrf multiplexcount
digitdone
movf PORTAtemp, W
movwf PORTA
bcf INTCON, TMR0IF
;Interrupt gets here every 1024 cycles, so subtract 1024 from a
;counter that was preset to 1000000.
;When the counter overflows add 1000000 so there are no cumulative
;errors
movlw 4
subwf microsecondsM, F ;microseconds - 1024
btfsc STATUS, C
goto ISR_end
movf microsecondsH, W ;check if zero
btfsc STATUS, Z
goto reset_timer ;1 second is up
decf microsecondsH, F
goto ISR_end
reset_timer ;just add 1000000 (0x0F4240) to microseconds
movlw 0x0F
addwf microsecondsH ;no need to check for overflow
movlw 0x42
addwf microsecondsM ;no need to check for overflow
movlw 0x40
addwf microsecondsL, F
btfsc STATUS, C
incf microsecondsM, F
bsf second_flag, 0
ISR_end
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
;table is at start to avoid page crossing
bcdto7seg ;bit 2 not used here (decimal point)
addwf PCL, F ; Jump into the lookup table
retlw B'11101011' ; Return segment code for 0
retlw B'00100001' ; Return segment code for 1
retlw B'10111010' ; Return segment code for 2
retlw B'10110011' ; Return segment code for 3
retlw B'01110001' ; Return segment code for 4
retlw B'11010011' ; Return segment code for 5
retlw B'11011011' ; Return segment code for 6
retlw B'10100001' ; Return segment code for 7
retlw B'11111011' ; Return segment code for 8
retlw B'11110011' ; Return segment code for 9
return
init
MOVLW 0x20 ;clear files
MOVWF FSR
NEXT
CLRF INDF
INCF FSR, F
BTFSS FSR, 7
GOTO NEXT
clrwdt
banksel OPTION_REG
movlw b'11000001'
movwf OPTION_REG
banksel INTCON
movlw b'10100000' ;timer0 on interrupts on
movwf INTCON ;prescaler 4 so interrupt every 1024 cycles
banksel TRISA
movlw b'00010001'
movwf TRISA
clrf TRISB
movlw b'10001110'
movwf ADCON1
bcf STATUS,RP0 ;bank0
movlw 0x0F
movwf microsecondsH
movlw 0x42
movwf microsecondsM
movlw 0x40
movwf microsecondsL
main
btfss second_flag, 0
goto normal
bcf second_flag, 0
incf seconds, F ;just increment seconds and digits to display
movlw d'60'
subwf seconds, W
btfss STATUS, Z
goto update_display
clrf seconds
incf minute_units, F ;easier to store digits separately
movlw d'10'
subwf minute_units, W
btfss STATUS, Z
goto update_display
clrf minute_units
incf minute_tens, F
;do some more checks to see if total time elapsed
update_display
;calculate digit0pins and digit1pins
movf minute_units, W
call bcdto7seg
movwf digit0pins
movf minute_tens, W
call bcdto7seg
movwf digit1pins
normal
; remaining code goes here (needs to take less than 1 second)
goto main
END ; directive 'end of program'
Slow start?The quot has been approved. Now we begin.
