Alternatives to TinyCAD?
tjohnson
Joined Dec 23, 2014
611
I like the simplicity and ease of use of TinyCAD and it works for what I need it to, but I have some issues with it.
If I export a circuit with no components selected, a huge image gets exported with a lot of blank space. When I select all the components before exporting it, the edges of some of the text labels get cut off. I worked around this by drawing a white rectangle (invisible against the white background) around my circuit.
The components in the generic library have red wires connected to them, but the default wire color is blue. I really don't care about colors in my circuit diagrams anyway, so I tried exporting a B&W image instead of a color one. However, then the rectangle appears around the perimeter.
I would also like to be able to use a bigger font, but it doesn't seem possible to change the font that is used. Regrettably, it seems like the development of TinyCAD has stagnated.
I took a look at Fritzing, but the interface seemed hard to use. I noticed that a lot of members of this forum use LTSpice, but that seems more advanced than what I would want right now. Does anyone know of a good simple CAD software other than TinyCAD? It would be nice if it could be cross-platform as well, although right now I'd only be using it on Windows.
EDIT: I forgot to mention that currently I'm only open to using something free.
tjohnson
Joined Dec 23, 2014
611
I've learned to work around most of the issues I had with TinyCAD, and I can live with the rest. I think it's a shame that development of the project appears to have come to a halt. I guess many of the members on this forum use LTSpice.
33,087
Another option is TINA, which can usually be had for free or for a very low price (like $9). I've only played with it a bit, but it doesn't seem too bad. As you say, LTSpice is very common and there are advantages to working with a simulator that is broadly used and supported. If it's more advanced than what you need right now, just learn to do what you need and don't worry about the rest. The price is sure right.
tjohnson
Joined Dec 23, 2014
611
Just as an update KiCad 4.0.1 was released in December 2015. Plus new Manuals in PDF.
I made a schematic with it, and couldn't figure out how to align components vertically or delete pins on an IC. Do you know if these things are possible in KiCad?
tjohnson
Joined Dec 23, 2014
611
I tried LTSpice again recently, and I don't like it at all. I couldn't even add a basic chip like the LM386 without having to download a subcircuit, open it as a text file in LTSpice, and create a schematic from it. This seems like a pain to me, and a lot more complicated than it needs to be.
