Alternating flasher question...
italo
Joined Nov 20, 2005
205
I think I answered this before. THIS circuit will work until 4.5v from 18v. by adding a regulator then it will work until 4.5v +2. You should add a regulator only if the timing is essencual. if you do that then use only for the lm555 timer and at the AND gate add a pull up to battery that makes an AND gate as opposed to open.
Wendy
Joined Mar 24, 2008
23,852
And the LEDs and the transistors driving them? That has been the subject of conversation.
