Is there an ammeter that can measure average value of alternating current for half cycle?
Not exactly what he wanted in my opinion. A half wave rectified input is at or near 0 volts for half a cycle which will of course lower the average. He wants the average of just the half cycle of interest. The TS/OP may have to clarify what it is exactly that he wants.Most ballistic analog meters measure the "average" value of a half-wave rectified AC wave.
Most cheap DMMs measure the "average" value of a half-wave rectified AC wave.
My expensive Fluke DMM will measure the true RMS value of a half-wave rectified AC wave.
No, the slap was completely unjustified and unprofessional.the thing is, my teacher asked me why we can't use normal ammeters for ac measurement, i told him that in our country where ac frequency is 50Hz the current will change its direction 100 times in 1 sec which is too much fast for a ammeter to measure, he slapped me hard(it really hurt) and said that is not a valid reason and said that the correct answer is that ammeter measure average current which is 0 for a whole cycle in ac.So i just had a burst of curiosity and wanted to know about the above. thank you for answering the question. Tell me one more thing, was my answer that bad that i had to get slapped?
Sorry Mike I still think you are wrong in you interpretation, but who cares anyway? Certainly not me.
BTW. The reason that we use the RMS measurement of a sine or cosine waveform is the RMS voltage times RMS current gives the same answer for power in a resistive load that integrating the waveforms over a single cycle gives. That is an enormous advantage in simplifying the calculation since the RMS value has a well known relationship to the peak value.Is there an ammeter that can measure average value of alternating current for half cycle?
You should show your teacher that you can use a diode in series with a DC ammeter to make an AC ammeter. How does your teach claim that an AC ammeter is made?the thing is, my teacher asked me why we can't use normal ammeters for ac measurement, i told him that in our country where ac frequency is 50Hz the current will change its direction 100 times in 1 sec which is too much fast for a ammeter to measure, he slapped me hard(it really hurt) and said that is not a valid reason and said that the correct answer is that ammeter measure average current which is 0 for a whole cycle in ac.So i just had a burst of curiosity and wanted to know about the above. thank you for answering the question. Tell me one more thing, was my answer that bad that i had to get slapped?
No. It was a reasonable answer and has some validity to it. If the AC frequency were low enough you would be able to see the meter needle move back and forth (assuming it is of the centered-zero type, which most aren't) as it tracks the current throughout the cycle, allowing you to note the peaks.Tell me one more thing, was my answer that bad that i had to get slapped?
Well my teacher told the answer a day before and i didn't attend the lecture at that day so he was pissed off i guess.No. It was a reasonable answer and has some validity to it. If the AC frequency were low enough you would be able to see the meter needle move back and forth (assuming it is of the centered-zero type, which most aren't) as it tracks the current throughout the cycle, allowing you to note the peaks.
No answer made in good faith should result in punishment of any kind. Now, if you had been insolent or flippant, that MIGHT be a different story, but that seems highly unlikely in this case. In the U.S. (and I suspect elsewhere) the teacher would have been in big trouble for hitting a student regardless of the reason.
Reconsider that thinking. You are the consumer buying an education from him. You have every right to judge him, and in many school environments you would be asked to do exactly that, to rate your teachers on a handful of criteria. The ones that get low scores are soon gone. Sometimes we have to hold our tongues, but don't be afraid to seek superior teachers.Also my teacher is kind of dumb(i know its not my job to judge him) ...
Your teacher had no reason for slapping you and, if there were witnesses, should be reported for assault. He has no business being a teacher.he slapped me hard(it really hurt) and said that is not a valid reason and said that the correct answer is that ammeter measure average current which is 0 for a whole cycle in ac.
You never know how that might turn out. I had a teacher (actually, I never took a class from him, just had a fair amount of incidental interaction with him) that went to break up a fight between a couple of the school's tough guys. I happened to see it because it was right outside his class room and I was on my way to class next door. One the students decided that no teacher was going to interfere with his need to put the other guy in his place, which is how I first found out that this diminutive guy was the state's reigning full-contact karate champion in his weight class. Needless to say, came as a surprise to the tough guys, too.Had he made the mistake of slapping me, I just might have put him in the hospital.
Well fortunately this particular proposition has never been put to the test. I think my reaction would be more instinctive than the result of careful consideration.You never know how that might turn out. I had a teacher (actually, I never took a class from him, just had a fair amount of incidental interaction with him) that went to break up a fight between a couple of the school's tough guys. I happened to see it because it was right outside his class room and I was on my way to class next door. One the students decided that no teacher was going to interfere with his need to put the other guy in his place, which is how I first found out that this diminutive guy was the state's reigning full-contact karate champion in his weight class. Needless to say, came as a surprise to the tough guys, too.
by Jerry Twomey
