Alinco DJ-180 handheld transceiver, low audio output
upand_at_them
Joined May 15, 2010
939
Probably not a bad idea to go ahead and replace the electrolytics, huh? They're at least 26 years go. Radio is made in Japan, though...good build quality.
sghioto
Joined Dec 31, 2017
8,765
Definitely C110, if it's defective it might show some voltage on the negative pin of the cap.
Can you scope both sides of the cap?
upand_at_them
Joined May 15, 2010
939
The input (+) side of the audio output cap (C110) shows 5V p-p at max volume while the output (-) side of the cap shows about 100mV p-p. I guess this could have been diagnosed with just a multimeter?
Thanks very much for the help!
upand_at_them
Joined May 15, 2010
939
I'll post back after the repair. I have neither a reflow oven, nor a hot air pencil...But it looks like my 1/64" tip Hakko can get in there.
upand_at_them
Joined May 15, 2010
939
I did rip off one of the pads. I think it's fixable, though. It appears to only connect to the white wire. I have the pad, so I can epoxy it down.
After the pad lifted I removed the rotary encoder (image in post #36) at top-left to give me more room so that I didn't mess up the other pad too.
upand_at_them
Joined May 15, 2010
939
While fumbling with the worklight for a better picture I found out that light from under the board really shows up the traces. Yep, it only goes to the white wire.
upand_at_them
Joined May 15, 2010
939
And it works! I used the white wire to bridge to the repaired pad. Immediately after that I powered it up and volume is normal again.
I still have to resolder the rotary encoder that I removed, and the antenna BNC, do a general cleanup and reassemble. And replace the channel EEPROM (SOIC). This HT will probably see some service in high altitude balloon tracking, which was the original reason I bought it. I had occasionally used it on my desk, but the audio just quit out of the blue.
Thanks for the help @sghioto. And for the earlier help from others.
govillard
Joined May 2, 2022
Hi to every body from spain.
I´ve repaired several audio problems just replacing electrolitic condensers from AF circuit.
Some standard like C112 and similars had this "age problems".
Some kenwoods failed about audio, TX and RX issues, almost always due to electrolitic capacitors leaking.
If you change them early, may be acid has not destroy circuitery. Sometimes is too late and is neccesary to repair circuitery lines.
Abut Alinco DJ-180, I had a look to schemes and I saw there were two electrolitics caps at AF power side.
I opened the radio and I saw this aluminuim caps. When I tried to desolder, they smell bad, tipycal very old caps.
I could only desolder one side of the caps, so I cut them with help of a sharp and little electrical sccisors.
Once I cut the aluminum, I removed the remains of the cap with tweezers. Then I was able to desolder the small portion of the leg of the cap, and finally a good cleaning with isopropyl alcohol.
Finally, I have used new tantalum caps to replace the aluminum ones. They are smaller, easier to weld and relocate.
Now its working fine, with very good audio power.
Ciao.
