Algorithm for FIR filters
atferrari
Joined Jan 6, 2004
5,022
18F family - Assembler.
I intend to program a micro to filter (FIR) a noisy audio signal. Prior starting to code I would like to be sure I got it right, thus my questions:
1) Basis this sequence http://i1000.photobucket.com/albums/af124/atferrari/FIRalgorithm.jpg, am I right if I implement this:?
V0 = Vin0 * h0
Output V0 to DAC
Wait delay time
V1 = (Vin1 * h1) + V0
Output V1 to DAC
Wait delay time
V2 = (Vin2 * h2) + V1
Output V2 to DAC
Wait delay time
VN-2 = (VinN-2 * hN-2) + VN-3
Output VN-2 to DAC
Wait delay time
VN-1 = (VinN-1 * hN-1) + VN-2
Output VN-1 to DAC
Wait delay time
V0 = Vin0 * h0 (??)
Output V0 to DAC
Wait delay time
2) When repeating the sequence with the following set of samples, is VN-1 from the old one, added to V0 of the new set?
3) If I process the signal off-line and do the output to the DAC module at a later time I will be using the same delay used for sampling, right?
The only way to go is using high priority interrupts to ensure a steady pace. Do you agree?
4) I have no access to MATLAB nor the so called "clones" which I do not plan to install for now. Any suggestion for a free software that I could use to calculate coefficients, maybe online?
5) Not now but in the future I expect the signal to be also affected by echoes of itself? What type of filter should I consider?
6) Have read on the necessity of an analog antialising filter previous to the ADC. Any comments?
Absolutely new to all this. Gracias for any help
thatoneguy
Joined Feb 19, 2009
6,359
VHDL Source for FIR Filter
Well commented, 32 tap filter.
For your other question: Offline processing/filtering is done a byte or few at a time, and as some signals cannot be processed realtime, the results are saved at the bitrate they were read once processing is complete.
