The camera is ntsc ,the output connector is bnc.Not enough information.
What is the output of the camera? What is the input to the monitor?
Have monitor 10 inch size monitor have VGA and RCA input jacks.hi mrel,
When you say a monitor, is that a PC type monitor.
Have you tried plugging the camera into a TV set, thats fitted with AVI connectors.?
E
When i connect the camera to the monitor WITHOUT using a DVR get No picture when using a DVR i get picture.First, I have not seen any DVR that has a video display, so we need to know what is displaying the image when you connect the output of the camera to the DVR. In fact, what sort of adapter are you using, and what is the input to the DVR? And what output from the DVR are you using to feed what monitor? Without enough information the best you can expect is guesses. In addition, have you verified that the video input jack on the TV set even works? I had a TV where the set worked fine except that the video input connector was disabled in the setup program. So we need a lot more details to understand the situation enough to provide a useful answer.
And the model number of the camera is not enough, we would also need to know the brand name of the camera.
