Hi everyone,
I have 3.3 V analog as well as digital voltage and 0V as AVSS. I am using unipolar power supply to power ADS 1298 . Please tell me how much voltage should i apply in vrefp pin with circuit and component to connect. I had refer to datasheet and it explain 2.5 V but i saw a schematics online (attached) which has +2.5v and -2.5V as AVSS but the datasheet explain that VREFP must be AVSS+2.5. But in the schematic i had found, whose AVSS is -2.5v and AVDD is +2.5 v which clearly violet the datasheet rules. So i am confused and need a solution.
