- Joined Jan 23, 2018
- 28,486
WHERE that capacitance gets added is what makes the difference. Consider that the meaning of "SHUNT" is quite different from the meaning of the word "EXTENSION."
Shunt capacitance on an antenna structure will need to be between two points separated by some amount of inductance. That is not possible at an end.
This is an instance where the exact meaning of a word really affects the meaning of the statement.
So you need to visualize the antenna as a string of inductors in series, which is what the antenna simulator software does. Each of those inductors has the inductance and capacitance of a section of wire of that same length. So a shunt capacitance is in parallel with that inductance, effectively cancelling part of it. Simple in a simulator, difficult in the physical world.
