ade7758 issues
Inventer $
Joined Apr 27, 2025
my names is Sidolphe , am imbedded system dev ,i designed a smart meter with stm32h750vbt,the mcu work well but the measurements part has issues, when i supply the ade7758 with it supply voltage 5v,it is becoming hot and draw more than 1,98A and the voltage drop to 3,2v .what cause that heat. I did every thing doing a star point between analog and digital ground ,also but the divider circuit on SPI pin but still the issue not solved.
28,492
Many digital meter circuits demand that the measurement input common side circuit be completely isolated from the power supply circuits. Connecting the two will destroy some digital meter IC devices. What I see is that the measurement common side, tagged as Vn, pin 13, is tied to the power supply ground at the junction of C1 and C2. THAT may be the problem.
Can you post the application sheets for this IC, please?
