Adding on/off button functionality to bluetooth servo.
Discussion in 'Programmer's Corner' started by jgreene44, Feb 6, 2017.
  1. jgreene44
    Dec 8, 2016
    108
    Thanks in advance for being here. The title pretty much says it. What the situation is. I have the Bluetooth servo setup going no problem.
    However. One of the servos is set for continuous rotation. it will not stay at a halted position for long. It will stop. but i guess the tiny bit of
    miscommunication is causing it to drift and start moving. Im wondering how can I add a button to this sketch that will turn that pin/servo off.
    getting it setup in MIT app inventor I think I can handle. It is the code that is killing me. I have tried a bunch of stuff, no luck. Here is the code
    I am working with:
    (this code is setup and working properly, I just need to devise a way to make that one servo stop completely.)
    #include <SoftwareSerial.h>
    #include <Servo.h>
    Servo myservo1, myservo2, myservo3, myservo4, myservo5, myservo6;
    int bluetoothTx = 7;
    int bluetoothRx = 8;
    SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
    void setup()
    myservo1.attach(9);
    myservo2.attach(10);
    myservo3.attach(11);
    myservo4.attach(3);
    myservo5.attach(5);
    myservo6.attach(6);
    //Setup usb serial connection to computer
    Serial.begin(9600);
    //Setup Bluetooth serial connection to android
    bluetooth.begin(9600);
    void loop()
    //Read from bluetooth and write to usb serial
    if(bluetooth.available()>= 2 )
    unsigned int servopos = bluetooth.read();
    unsigned int servopos1 = bluetooth.read();
    unsigned int realservo = (servopos1 *256) + servopos;
    Serial.println(realservo);
    if (realservo >= 1000 && realservo <1180){
    int servo1 = realservo;
    servo1 = map(servo1, 1000,1180,0,180);
    myservo1.write(servo1);
    Serial.println("servo 1 ON");
    delay(10);
    if (realservo >=2000 && realservo <2180){
    int servo2 = realservo;
    servo2 = map(servo2,2000,2180,0,180);
    myservo2.write(servo2);
    Serial.println("servo 2 On");
    delay(10);
    if (realservo >=3000 && realservo < 3180){
    int servo3 = realservo;
    servo3 = map(servo3, 3000, 3180,0,180);
    myservo3.write(servo3);
    Serial.println("servo 3 On");
    delay(10);
    if (realservo >=4000 && realservo < 4180){
    int servo4 = realservo;
    servo4 = map(servo4, 4000, 4180,0,180);
    myservo4.write(servo4);
    Serial.println("servo 4 On");
    delay(10);
    if (realservo >=5000 && realservo < 5180){
    int servo5 = realservo;
    servo5 = map(servo5, 5000, 5180,0,180);
    myservo5.write(servo5);
    Serial.println("servo 5 On");
    delay(10);
    if (realservo >=6000 && realservo < 6180){
    int servo6 = realservo;
    servo6 = map(servo6, 6000, 6180,0,180);
    myservo6.write(servo6);
    Serial.println("servo 6 On");
    delay(10);
    I'm sure the ways I tried where plenty ignorant. So I won't bother to add that info. However I did find this bit of code that I was trying to utilize:\
    String voice;
    void setup() {
    pinMode(13, OUTPUT);
    Serial.begin(9600);
    void loop() {
    while (Serial.available())
    delay(10);
    char c = Serial.read();
    voice += c;
    if (voice.length() > 0)
    Serial.println(voice);
    if(voice == "on")
    digitalWrite(13, HIGH);
    if(voice == "off")
    digitalWrite(13, LOW);
    voice="";
    I know someone is going to say this is easy. I simply am not knowledgeable enough yet. I am working on it!
