adders don't work..
jun
Joined Dec 4, 2008
8
Hello, everybody
I designed CMOS and CPL full adders but they don't work..
both CMOS and CPL XOR gates work correctly but when I put them into the adder circuits, the results don't make any sense.
Is there anyone has idea what is the problem? At first, I thought it was a problem with CPL transistors, cause this was my first time to design CPL logics. But CMOS adder also doesn't work correctly, so I think it's not a problem with CPL. Then, I thought it was a MOS sizing problem so I tried to fix it, but I have no idea which one I have to change.
Please let me know what's the problem and possible way to fix.
I'm working in Cadence Virtuoso.
Thanks.
bertus
Joined Apr 5, 2008
23,026
Why do you say that you can not place pictures?
In the FAQ is the following text about this :
How do I attach a file to a post?
To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread.
On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'.
Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen.
What files types can I use? How large can attachments be?
In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board.
How do I add an image to a post?
If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing
after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.
Greetings,
jun
Joined Dec 4, 2008
8
Thanks a lot. I hadn't checked FAQ and/or other menus cause I just joined yesterday.
I will check them from this time. Thank you again.
jun
Joined Dec 4, 2008
8
By the way, I have a new question if I may ask here.
To design low power circuits, I'd like to use MTCMOS. Then, is that all putting 2 High Vth MOS next to Vdd and Gnd? I am trying now, but I have no idea which signal I have to use from the original adder as a "sleep" signal which open or close those High Vth MOS. Do I have to have 1 more input signal?
Thanks.
