Add line-in jack plug to FM radio
Status
Not open for further replies.
28,262
"B" is correct in that the volume control is not the audio input point, and will not work that way. Given that the entire radio circuit is contained in one IC device, the actual audio input voltage range is unknown. So while you could make the connection as described, I do not recommend doing it.
Status
