ADC to measure battery voltage
champ1
Joined Jun 4, 2018
136
I have a question regarding little bit maths,
If I want to measure the voltage with adc and voltage range is between 0 - 30 V DC
For example
I have 8 bit adc and adc working with 5v DC
8 bit adc can count 2^n = 0 - 255
How can I measure voltage range 0 - 30 V DC with 8 bit ADC ?
ericgibbs
Joined Jan 29, 2010
21,570
hi,
Usual way is a resistive voltage divider, when the top of the divider is at 30V the junction is at 5V.
Can you calculate that OK,? keep the resistor values less that 10K
E
KeithWalker
Joined Jul 10, 2017
3,618
For example
Use resistive divider to drop the 30 v to 5 v and then divide the output from the ADC by 8.5.
champ1
Joined Jun 4, 2018
136
V2 = V1 * R2/R1 + R2
where R1 = 50000 ohms , R2 = 10000 ohms
if V1 = 30 V DC
V2 = 30 * 10000 / 60000 = 5 V DC
if V2 = 15 V DC
V2 = 15 * 10000 / 60000 = 2.5 V DC
Calculation prove if the battery voltage is 30 v DC then ADC will get 5 v input signal and if the battery voltage is 15 v DC then ADC will get 2.5 v input signal
It means we can measure voltage range 0 - 30 v between range of 0 to 5 V DC
champ1
Joined Jun 4, 2018
136
In case if we want to measure 0 to 30 A DC,
then How can we measure current
I don't think ADC will read current signal
ericgibbs
Joined Jan 29, 2010
21,570
hi,
The usual way is to have a very low value resistor in which the current flows thru, you get a small voltage drop across the resistor.
The small voltage has to be amplified to say 5V for a 30A current OK.?
E
champ1
Joined Jun 4, 2018
136
hi,
E
so we measure the voltage drop across a resistor then use an op-amp to scale this up to 0-5V for the ADC
there are current sensor available in market to measure current
let's take example if I use one current sensor or circuit that can measure current between 0 to 30 A
current I = V / R
We need to know voltage and resistance
How do we calculate load current with 8 bit adc ?
What's formula needed to calculate load current using adc ?
ericgibbs
Joined Jan 29, 2010
21,570
If you had a 5V signal from the amplifier when the current was 30A, then 5V would represent 30A,,,, 2.5V =15A and so on.
Say you used a 0.01R series resistor, with a current of 30A that would give a voltage drop across the resistor of V= 30A * 0.01R = 0.3V
You would amplify that by 5V/0.3V = 16.6 times, so the input to the ADC would be 5V at 30A.
Do you follow that OK.?
E
EDIT:
Simple LTS image.
dendad
Joined Feb 20, 2016
4,641
To measure current, have a look at ACS712 chips.
https://www.ebay.com.au/itm/5A-20A-...hash=item41c9afd40d:m:mudhcL9ercx9TGlLtfoejGQ
These sense the magnetic field of the current and produce a voltage out that you read with the ADC.
The advantage of these is you do not need a sense resistor. And they can be placed in the hot side of the supply if you want as there is no electrical connection to the current path.
A trick too, placing a magnet near then will alter the offset.
danadak
Joined Mar 10, 2018
4,057
Questions -
1) What range of current you want to measure ?
2) Resolution of current measurement ?
3) Accuracy of current measurement, relative or absolute ?
4) Current unipolar, or one sign ?
5) Measure high side or low side of load ?
To measure current use a processor with differential input, DelSig type
converter, and a low valued R, like 1 Ohm.
Note just drag and dropping a mux for front end to DelSig will
allow it to do the V measurements as well.
An example -
Regards, Dana.
